Engine stays on
Just checking to see if anyone has some crazy insight before I go tracing wires.
2002 rinker 342 with 6.2 engines. Starboard had trouble starting. I cranked on it pretty good, finally got it fired up. Now it won’t shut off with the key and I’m getting constant power to the dash even with key off/all wires removed from switch etc. somehow it seems the engine is back feeding power. Only way to get it to turn off is literally unhook at the engine.
Anyone better with electrical than me?
TIA
the key switch turned to start JUST operates the relay, and the relay is common to go bad. that's manifest by no nuthin when you turn it... this one, though, is stranger... it seems a bridge is making connection over the coil wire (purple wire) when you attempt to kill engine... that would be my guess, and i would also guess corrosion as the culprit- it needs to carry only a few watts- so hardly ANY connection is going to cause that.....
i'd imagine the place to look first is in the engine room... find the purple wire leading to your coil pack and hit it first with some wire cleaner, then with some protectant after the cleaner dissipates.. it may and likely is something you can actually see... if that doesn't get it, pull the dash panel and look for the purple wire to key switch- that usually heads to the tachometer after that (it's the signal that tattles on the engine speed)... look for corrosion, clean corrosion, protect against future corrosion all with the spray cleaner and protectant...
the other place to look if that doesn't take care of it is the same starter relay (your big red button reset is attached to the same bracket) and find the wires that lead to the ignition module and give them a cleaning.
