8.2 Charging question
earl1z19
Member Posts: 369 ✭✭✭
I have an 8.2 with Axius and vessel View. The Starboard side is showing 14.2 volts when running. The port side is fluctuating from 13.2 to as high as 13.8. The alternator is putting out 14.75 volts. The battery is showing 12.7 volts with the engine off and 13.5 or so with the engine running. I have cleaned all the contacts as well as the alternator output wire. Any ideas on what to look for to get the charging voltage above 14v? The only item I did not check is the molex plug on the alternator.
Any other suggestions?
And kind of a dumb question but are both battery banks multiple batteries? Have you made sure you don't have a weak battery(load test) port side that could be sucking down the power.
Having things like refrigerators and high power stereo systems running at anchor can suck down the battery juice quickly. A deep cel battery doesn't like running down past about 12 volts. It can do it but at the expense of its life span. Those that run down battery banks often need to test all batteries on that bank often as if one dies it can take out the other quickly if not caught in time.
