Scary situation on Sunday - total loss of power inside marina in tidal creek
I managed to get out of this with relatively-minor damage, but as a new boater, the event last night has me scared to go out again - at least for a while. While pulling into the marina, which is along one side of a 75 yd wide tidal creek (there is a marina across that runs the other side), I approached my slip, ran my bow thruster to get me ready to back into the slip (something I'm admittedly not great at yet). Suddenly, steering becomes impossible - starboard VP 5.7 GI-E had low voltage alert and had died. Now, as the exiting tide starts to take control of this large 36' 360 FV, I worry about what I'm going to hit having no ability to steer. The bow thruster sounded weak and was little help. Then, the port engine dies. I'm adrift. We are facing the way we are going - out with the tide, but we come up on a fishing boat with a long nose and we take its windlass anchor down the side - small gouge chip and scrapes for about a yard after it - fishing boat was fine. I drop anchor and eventually it holds. I emergency switched starboard to port battery and get it started eventually. Then I get port up, but starboard engine still seems weak, but at least it's covering the power steering. I finally get her in the slip. This morning, I'm still in a bit of a PTSD over it. After a night of charging, the starboard battery shows little more than 12.5v and the SirenMarine stats show it dropped from 13.5 during the day yesterday as we were out having fun. Possibly I left the thruster power on all day, even though the generator was on most of it? I believe the bow thruster shares with the stbd battery. I tried the bow thruster in the slip and it sill sounds weak. Should I assume a bad battery or alternator or both?
Dan of Steel
'05 Rinker 360 Fiesta Vee
As a confidence booster, before entering a marina, take a quick pause to prepare. Make sure you have quick access to a boat hook, a line, a fender. The fender provides a cushion between you and the nearest anchor if things go sideways.
That chart is the starter battery? During the week, you're seeing 13V because that's what the charger is feeding it. Left on its own, it went to 12.3 ... sounds like that battery needs help.
Does the battery have removable caps? If yes, get a gallon of distilled water and top off each of the cells. Wait 24 hours and see if it holds a charge.
I would guess that the thruster was not installed at the factory if the battery and charger aren’t in the v-berth somewhere. The thruster charger breaker was wired to a plug in my v-berth.
It's like in some older homes: if a person is taking a hot shower and you flush the toilet, you'll hear bad words from the person in the shower.
The alternator feeds the battery, and the battery feeds the engine. If the thruster starts drawing 200+ amps, it's going to pull the voltage down. At some point, I <suspect> the low voltage could stall the engine. Just a theory.
ProMariner will cover the 2 house and 2 starting batteries, since I can't count the house as a bank on this - has to be 1 output per batteryNOCO will be for a new thruster battery
If you want to keep everything in the engine room, I don't think you necessarily need a second charger.
A house bank can have any number of batteries wired in parallel, and the charger sees them all as a single large-capacity battery. You don't need separate charging circuits for each house battery. So the 4-bank ProMariner could charge port, starboard, house and thruster.
I would get a charger with four outputs and do as @LaRea suggests.
I ran a digital load tester on the 2 starter batteries and both were in bad shape, so replaced those with new Deko 24/1000s and got a 3rd for thruster.
