AC Compressor Cycling
YYZRC
Member Posts: 5,364 ✭✭✭✭✭
Trying to understand normal behavior of a marine AC unit.
I have the 16k unit commonly found in the 330/350 of the 2008 era. It cools great, however, the compressor cycles off and on seemingly at random (and before setpoint is achieved). When it happens, the compressor cycles off and the pump does not stop. After a brief pause, the compressor will kick on again. The unit is not icing over.
Once the desired temp is reached, the compressor and pump shut off as they should.
@Handymans342 or anyone else, any thoughts?
Thanks
Thanks
I don't know if you have such an item.
On an 90 degree day with 89 degree water, mine will activate more than a few times.
Is your thermostat like mine, way to fancy? I don't need a programmable one. I want to turn it to heat, cool or off. Fan auto or on. Last but not least the desired temp.
I don't need touch screen on a boat.
