New 2008 Rinker 280 EC - Air Cond. issue
mvgvb
Member Posts: 46 ✭
Hey All,
After weeks of servicing and transport delays, finally got our new (to us) 2008 Rinker 280 EC into our marina in RI, from fresh water in NH.
Haven't taken it out yet, but was down there this evening to load on some gear and couldn't get the Air Conditioning to work. It would turn on, and clearly could feel the cold air for about 2 minutes, and then we would get a "HPF" error on the system control and it would just start blowing hot air. There was also no water coming out of the hull when the A/C was running like it normally would.
Any thoughts on this? I've read we need to close the seacock and check the strainer, which I'll do tomorrow, but I can't imagine that's the issue. We were on the boat a few weeks back and it worked perfectly, and it hasn't been used since. We also had it surveyed and they checked the strainer at the time.
Only thing that's happened since then is that it was pulled for servicing and transport, was likely out of water for ~2 weeks. I've read this can cause some issues with air getting into the lines? Or otherwise maybe a random control was turned off during servicing that I can't find?
The only other change is that we pulled it from fresh water and dropped into salt water, but I wouldn't think that could have an impact on anything in just a few hours.
Appreciate any help!
What's the best way to prime the AC while sitting in the slip? Dealing with a sick baby as well right now, so taking it out for a ride may not be in the cards.
Thanks!
when I turn the AC on I can hear the pump, and even feel a small amount of water spurt through the exit hose, but nothing comes out the side of the boat.
I have seen boats where to prime you need to pull the hose at the pump, then pull the input hose to the AC unit itself, but hopefully just the output hose on the pump will do it for you.
And you’re saying just hold a hose from the shore water up to the discharge through hull and let water flow in reverse into the AC?
I would suggest if you're going to do it that way to trace your lines from the condenser out so you know for sure which one to prime.
