2002 fiesta vee 270..2 bilge pumps..w/float switches fail to pump water?
Unless key is turned on and bilge button is pushed...then they work fine..
I am connected to shore power,..
battery switch turned to "off"
What the heck is going on here..?
should I leave the battery switch to "both'?
if I leave the batteries on ,will they run down?
even if my batterey charger breaker is engaged?
I was told to dial battery switch to "off" when shore power is on.and put battery charger switch on...
bad advice?
I left boat in this condition,when returning after a week of rain.. found 3 inches of water in the bilge!..took 5 minutes to clear...
now..
thinking of installing 3rd pump with stand alone battery as a failsafe..good idea?
bad advice?
now..
brand new batteries ran down in 3 days (with out) shore power hooked up, one time..I was told by seller to switch off batteries..to safegaurd batterys,no matter what.
Bad advice?
also..why does the radio not work unless key to boat is turned on??
connected problem?
even... with.... shore power engaged
All advice appreciated..
thanks.
put boat in water for the first time.
Hooked up to shore power..
everything working..no problem....
when leaving for the week...
left boat batteries to "off" position.
came back after week of heavy rain,3-5 inches of water in bilge .
after that...next week...Tried new angle.....to leave battery module set to battery ...on..but.... to battery 'one" only..
heavy rain again...
believe me..!!!really heavy...
I believe it was 3 inches in 24 hours!..
drove up to marina..not feeling good about things...
surprise!!!
boat was bone dry..?
What the....???
Did rain not get in ?for some reason???
Did float switches.(original) (after 20 years..) do their job?
finally???
with , the right battery setting?
unsure...about why the bilge was dry in all this rain...???
originally..when I found the 3 inches in the bilge...
I switched the battery setting ,to all positions...All ways...to see if the pumps would go off...
Nothing
next... I inserted the key..hit the bilge pump.... and both pumps ejected the 3 inches in about 5-10 minutes...
I am befuddled...
going up this weekend...
I had a backup plan, of installing a completely different... battery ....complete with sole bilge pump and float switch ,ready to drop in to the hull..!!!
but wife said..forget it..boat is doing what it should..
I am confused..
I REALLY...
do not want to sink this boat in the freakin marina!!!
,being 3 hours away from it... in times of crappy weather is ....stressing me...losing sleep!
What would any of you do????in this predicament????
thoughts anyone?
(no hose available at the marina to test the bilge pumps... while there...)
just electric hook up..
thanks again...
pumped out.
just electric at the docks $800.
its a great sheltered marina.
rare... on the bigger lakes...
not complaining..but water would be nice...
good Idea..to check the other marinas..there are 2 I believe.
thanks.
