Fresh Water pump …might be time to replace it. Need advice / rinker 2006 390.
 scousine
                    Member Posts: 74 ✭
scousine
                    Member Posts: 74 ✭
                    Noticed that recently our fresh water pump located under the floor in the middle of the boat (for our water in the kitchen) started to give us trouble. Whenwe start the water the pump it start for 2 seconds , stop and restart every second with not a lot of water pressure. Is it time to replace? Or should we check something first? Any advice welcome. If should be replaced , any recommendation on model?  Thank you.
Don't bother with anything faster than 4 GPM. The constant on-off-on cycling will make the pump fail, and the sound is obnoxious.
