Kohler 5ECD generator throwing LOC error
LaRea
Member, Moderator Posts: 7,916 mod
My genny recently started throwing LOC (loss of coolant) faults. It starts fine, runs 15 seconds, then stops. The water flow from the exhaust is normal, so I tried disconnecting the seawater pressure sensor, and it ran fine for 2 hours under normal load. What else could be causing the LOC error? Faulty sensor?
I've been running it every week with no problems. The coolant and anode were replaced this year. The impeller is 3 years old, but again, it's pushing plenty of water.
[EDIT: It appears that replacing the raw water pressure sensor fixed this problem.]
Post edited by LaRea on
Replace the sensor if it ran fine disconnected.
I'd change impeller first, just because. Then change the sensor.
@Mbmike here's the water output:
So....changing the impeller fixed it? I do know even when it's spitting water it can still need changed. Pau Hana had LOC at Rinkervous this weekend. I got on him big time about not changing the impeller at the beginning of the year. He has an admiral that has to have a working generator. I always change mine at beginning of the year just so I'm not changing while at something like Rinkervous.
Nope, not yet. I certainly haven't pushed it for him. Too nice of a boat & too good of a boating friend.
I really didn't notice any difference in the water output before and after.
On my Kohler 5ECD, the part was $37 on Amazon.
https://www.amazon.com/dp/B06XTSTVW2
If you disconnect the sensor, will the genny start and pump water normally?
My sound cover bolts were all badly corroded, so I replaced them this year. Now it's much easier to work on the genny.
yep probably just jinxed myself
