Kohler 5e no spark or fuel
                    I believe I was tripping on LOP so topped it up, then it ran great for 5 min, now same issue again.
      Will sensor shut down if too much oil?  Dip stick seems basic at best. Any suggestions welcomed?
You can also use a multi meter and check to see if lop is grounded. They generally don't fail unless oil is allowed to get really nasty and sit for a long time in my experience. Fresh oil plus a little marvel mystery oil or seafoam can usually clean them in a good hour of run time, then change oil again
