Outdrive oil
I've mentioned that I changed over my Bravo-III oil from the Mercury stuff to a Neo-Synthetic gear oil 75W-90MRHD (Editied to correct oil ID) (www.neosyntheticoil.com) (http://www.bravoshop.net/index.php?main_page=index&cPath=182&zenid=nba5aetfvt6vns7rr8d4ssnvs6) based on the guy who rebuilt my outdrives (www.allamericandriveservice.com) recommendations. He uses / recommends it for all his high HP / heavy usage applications. I have about 80 hours on the oil (2 seasons) and just pulled samples to be analyzed to see how I was doing, all in all, excellent and no degradation of the lubricant.
The guy who did the results had extremely high praise for the Neo-Synthetic products and thought this stuff was out of the box thinking (in a good way). Attached is an analysis of the unused oil: key items: Phosphorous, lead, potassium, all anti-wear additives. The oil peforms at the 90w level and no breakdown at temp.
I have zero personal interest in the overhauler, oil supplier or testing house. Just people I have worked with that are unbiased on this stuff and my personal results so far. Stuff is not cheap, but compared to an outdrive, it is cheap and getting 2+ seasons out of it is even better savings. Something to consider if you are looking to upgrade your outdrive lubricant.
Note I corrected the oil ID info and a source for it too!!PC BYC, Holland, MI
x
x
x
x
x
Guys this is great information. I have a Bravo 3 drive on my 2004 232 Captiva BR so after reading this discussion I looked at my drive. It had the white chalky film on the upper half of the drive. I used Lime-away to get it off, then I immediately ordered a drive shower yesterday, that you guys recommended. I plan to change the drive oil to synthetic oil also. I know this post is for outdrive oil but I have used Mobil 1 full synthetic in all my auto engines (5 with kids cars) for the last 10 years for the same reasons you mentioned above. Any recommendations on this? I see Mercury makes a full synthetic engine oil, but I didn't specify this when I had it winterized last fall.
x
x
It's not JUST 2 right angles of gear pressure and counter rotating prop gears (as if that's not enough) that heats that upper outdrive when it's up on plane and pushing hard, it's the frikken HOT a$$ exhaust running back > down and out that gets 'er SUPER piping hot. Not an ideal mechanical combination. Best bet for any OD is to take it off plane every 15-20mins when cruising and let that sweetheart cool down a bit at trolling/trawler speed.
I know they've done torture testing for days on end but, as has been seen by anyone who has a chaulky film on the OD after a long day, these rascals run HOT. Give 'em a break now and then.....but put the best oil in them too. A stern shower is also a good bet, but it's still a hostile work enviroment back there.
Just sayin' Mike Have a great season.
