NO TACHOMETER MOVEMENT AT ALL?
BOTH ENGINE HOUR METERS WORK BUT WHEN YOU START THE ENGINE THE TACH NEVER MOVES FROM 600RPM NO MATTER WHAT THE ACTUALL RPM IS? BOTH ENGINES DO THE SAME THING CAN FIND ANY WIRING UNDONE. TWIN 350 HORIZONS PLEASE HELP
- If all else fails you could send in your tachs for replacement with $150e for their generous(not) replacement program.
- Or get a smartcraft gauge system that ties to your engine computer for rpm and host of other far more accurate engine info. (my eventual choice and I love it)
Good luck, MikePS you posted this in the "for sale" forum but I hope you haven't reached that level of frustration yet.
I own a 2005 320 and have sent the Faria gauges back 4 times in the past with the $150 donation and was just tired of the Faria tap as well as the inaccurate gauges. I went with Smartcraft this past winter. I also replaced my Radar/gps with a Garmin 741xs which I moved up to the top of the dash covering the right cup holder. I was tired of trying to look at the screen down to the left while I was cruising-I always stand when on plane. I will post pictures of my dash after I am at the boat this weekend. As for the Faria gauges-the tachs were off by 200 rpm and the temp gauge was off by 20 degrees. Glad I switched. Love the gauges but they are a little expensive-cost me $2500 to have marina install but I also added a drive steering angle gauge as well as a gas fume detector.
Like Serenity said above I wasn't too surprised to find that there was little accuracy in my Faria readings compared to the engine computer data. Here's the link to the install thread with pics. Look for my update post from around around Feb 2014 ((LINK)).
It ended up being a SUPER easy upgrade. Far less painful than the Faria $$exchange$$ .
Good luck in your search. Mike
Martin,
I took all the Faria gauges out--except the clock which was the only accurate one. This weekend when at the boat I will send you some pictures.
