1995 300v Express power trim
Can anyone tell me if there are fuses on the lower unit trims. Both quit working at the same time.
  • aero3113aero3113 Member Posts: 9,853 ✭✭✭✭✭
    edited July 2021
    Yes, there are. Strange that they both went out at the same time. There are two fuses, you can see in my pic below the yellow holder for a glass fuse and the red block fuse under the solenoids.
    Did you try the trailer switches also?
  • YYZRCYYZRC Member Posts: 5,464 ✭✭✭✭✭
    That bracket is pristine.  I thought even when new they were pre-rusted!
    And did you notice that aero just happened to have the perfect picture?
    LoL
    That pic is from when I replaced the bracket on my old ‘01 242.
  • bknoxbknox Member Posts: 2
    Much thanks!
  • LaReaLaRea Member, Moderator Posts: 8,070 mod
    On my 2003 342, they came pre-rusted from the factory, and the replacements that I installed were pre-rusted.  On my 2007 370, the brackets look brand new after 14 years.  Go figure.
