Leaking Trim Hose
So after more inspection of our
2001 340 Rinker Fiesta Vee it turns out our trim tabs are in fact hydraulic. Found the source of the leak to be the hose leading to the starboard tab but it appears that the hose has already been replaced at some point in the past. The port side looks original. Our mechanic is on holidays next week and after what he's been thru with the restrictions from Covid I'd say it's well deserved and can't look at it til the week after that. My concern is that given the line has already been replaced could that mean that the cylinder is crapping out and causing the line to fail? Or is there enough play and movement on these to weaken the line to a point where it'll burst? I think I already know the answer but any suggestions of a temporary fix til our guy can do it?
Rather than chasing the leak I would swap to electric. The hydraulic are really a pain. I think you can pick up a Lenco electric tab kit for reasonable $$ with cylinders and all required parts.
Does anyone thing this would be a good option? Kinda looks like plug and play pretty much?
http://insta-trim.com/heavy-duty-trim-tabs/parts-diagram/
Maybe you just repair the hose to get you through the season and then spend the winter finding a retrofit kit like the one above?
Found the suspected issue. Line burst inside the transom bore. My guess is the previous install was too tight causing a stretch and not allowing the extra length to compensate for the extra movement in the actuator? Anyhow, its now repaired for hopefully the rest of the season and I plan to replace everything this fall. Once again I like the idea of knowing exactly where each board is sitting via the lighted gauge so any and all recommendations will be appreciated. I don't want anything too complicated with features connecting it to other stuff but would like the lights. What is everyone else using? Also the plates are 11" X 18". I know that it seems a bit harsh replacing a whole system because of a burst hose but its a bigger pain having to bug my old high school buddy to haul it out for me when he has a business to run
http://insta-trim.com/shop/tab-locator-set-round-black-indicator-panel-25-harness/
