Mid cabin leak
mvgvb
Member Posts: 46 ✭
Hey all,
We apparently have a leak in the mid cabin berth in our 2008 280 EC. Seems like an odd spot for it, no other areas look wet. It’s definitely coming up from the bottom and and not leaking down.
We did have the bilge pump running accidentally for a while, but not sure that’s relevant.
Anyone seen this before?
Thanks!
Thanks!
Wife says the water smells a bit like vinegar, not sure what that indicates:
climbed in the engine compartment. Not only was that bilge at a normal level, but the wall against the cabin was bone dry.
I would have thought it would drain/overflow directly into the bilge, no?
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
The round cover over the AC has the buttons on each side and I think if you turn them they should unscrew. They are basically just screw covers.
So I assume it has been getting wet and you have had the AC running and no rain? Seems like you may have somewhat solved the problem now the solution.
Only thing I can think is the pan drain is clogged or maybe the water line to the compressor may have a loose connection or hole in the line.
