Proper RPM range
Wondering if anyone with a (2001) 340 FV can tell me the WOT range would be on our twin Merc 5.7 EFI's with Bravo III's 24 pitch Mercury props? I had it at 48mph GPS at 4200rpm's with more throttle to go? Does that seem like the right figure? Also sorry for the image coming in 3 times!
If you are satisfied with the time to get on plane, don't change anything!
Seems like its plenty fast to me!
Although I might add that the hill marine 4 blade prop on my bravo 2 worked miracles on my plane time and lowered my cruising...er plowing the water rpms.
Also one question off topic a bit we're heading to an island later this evening so what are some suggestions for increasing battery life over a couple day span. Can you shut down one of the fridges (say the one up in the cockpit?) and only use the one? Run the engines for a bit in the evening to charge the batteries and for how long? I plan to pick up a solar panel blanket that we can easily store when on shore power but haven't purchased yet. Any advice would be appreciated
Thanks in Advance
