NMEA 2000
davidbrooks
Member Posts: 1,432 ✭✭✭✭
i thought maybe we could start a thread on NMEA 2000. In doing some research i have really only found a limited amount of support out there. I am in the process of changing over to a digital dash. I have decided that i am going to simply go with two Garmin 942xs. on the dash and get rid of all the gauges. One will be for a chartplotter and the other for engine and other readings. I trust Garmin even though it is more expensive than others out there. I had a Simrad GO5 and ripped it out and tossed it and the transponder in the trash last weekend. The plan is to start replacing sensors or simply connecting what i have to an NMEA2000 sensor. All of the communication will run through a N2k backbone from the engine compartment to the dash. Engine info will be via connecting a Smartcraft Gateway. Then i need to get Fuel and Trim indictors. I am looking at the Garmin GFL10 and GTL10 for this. However at $200 each i started looking at others. Came across the Lowrance version for $95. The problem is i cant seem to figure out what the difference is...other than being 1/2 the price. Has anyone here have any experience with mixing around NMEA sensors? Do vendors put in proprietary capabilities with a sensor that can only be accessed by their MFD? For these two for instance i am thinking of calibration with empty and full. I feel confident going with the Garmin ones but i was just wondering if i could save my self some money.
I think my eyes got sunburnt over the weekend squinting at the screen going through all the setup options.
I think I did find it GET10 is the part number
https://buy.garmin.com/en-US/US/p/35607
Now if I save $200 that means I get to spend it on something else 🤑
