Transom Locker Strut Bracket
aero3113
Member Posts: 9,636 ✭✭✭✭✭
The strut bracket on the port side of my transom locker door pulled off. I went with bigger screws and it still pulled out after a couple of uses. I’m planning on drilling out the holes much larger then filling with epoxy and possibly fiberglass. Do you guys recommend any other way to fix this? I only need a small amount of epoxy and fiberglass.
Can you just move the bracket up or down a little, and drill new holes?
