Low voltage starboard side
YYZRC
Member Posts: 4,924 ✭✭✭✭✭
Isolator is new ProIsoCharge. Batteries are two year old AGM group 29.
VV reads 14.2v port, 11.8 starboard when engines running. Voltmeter on starboard battery (disconnected) reads 12.6v. I swapped batteries port to starboard, no change. I swapped alternators port to starboard, no change.
Now stumped. Thoughts?
At the isolator, starboard battery 1.8v, port 12.7v
Will now swap the charging breakers to see if that’s the issue.
I have the same remote battery switch setup.
