Inter Coastal around St Augustine and South
This site, as far as I know, does not really get to detailed with boating in a particular area, does it? For example, we are planning a vacation on our boat for a week south of St. Augustiine, a little north of the Mantanza inlet for those that know the area which is north east Fl. coastline....I have not been in this area by boat. It looks kind of deserted between the inlet and St. Augustine....which is kind of what we like....pull over to a little island and hang out. Anyone know the area? Which brings me to some questions I had posed probably last year on anchoring in areas like this....my worst fears are number one, anchor coming lose and watching the boat drift away, two, anchoring and because of tide changing, watching the boat swing around and ending up on shore or just basically, finding a spot with some water and when the tide go out either end up with no water or no water around me to get the boat back out. I know experience is the key here and frankly, I got not much to work with and less in dealing with tides. How about some words of wisdom for me? Is it safe to anchor out both ends of the boat to keep it from swinging with the tide or is that a no no anyway....
**Don't use an anchor off the stern unless you're backing up to the beach for the afternoon. If that's the case and you can leave some slack, set you bow anchor out 100' +/- then just ease back and set the stern anchor at the beach high/low waterline. Then let the boat drift back off the beach 10-20' and pull the boat back into the beach with the stern anchor line as needed.
**Don't anchor overnight in/near a channel that has a major current..... like Mantanzas has. Back up in behind the cove by the lighthouse or the state park should be far better. I prefer to pick my current free anchorage considering any expected wind overnight and any buggy shoreline that's too close to allow me a few 100' from a windward shore for a peaceful night.
**I always use Google earth satt images, chart programs and Active captain.com to research a few anchorage/marina choices before I leave. Read the local reviews of each anchorage to see what to expect and find a quiet cove out of the main current.
**The current rips through the municipal marina at the Bridge of Lions in downtown. Docking and line use are challenging but old town is a lot of fun. Just assess the dock current and tie it off in every direction.
** If I remember right there was a really nice marina just N of the cut that was spoken highly of.
**Again, lots of shoaling and current in that area. Be cool.
Have fun. Be safe and post some pics of that new ride. Mike
A lot of info is available on www.activecaptain.com
Plus cruising guides available from West Marine, one of them a guide to anchorages.
Hope this helps. Have fun.
Tony
Salt Shaker 342
normal typeface and floating aids with an italics typeface (a large
percentage of boaters don't know this.)
while searching the site, came back to a post I put up a while ago and with a few more months after that post, Mikes comments make a little more sense. After all, I have hit the down switch 2x on the windlass since then. Well, if you include the one time in my driveway.
So, did not go to this area but now planning a trip to Ponce Inlet/New Smyrna area and a popular sand bar at the jetty called disappearing island I have been there 3x but not with the 270.Its a little south of the above. I had a bow rider I could pull up on shore and watch for the tide albeit nervously. There is a point that goes towards to the jetty which shallow for way out and the north side is also shallow. If I anchor as Tiki states, if the tide changes while I am there, do I need to pull the stern anchor and let it swing or will the two anchors safely hold? I guess I need to watch the depths closely so I don't end up stuck as well...need a stick like you check fluid levels in tanks stuck in the ground so I can tell what the tide is doing as it moves fast in this area....
Have fun, be safe and post some pics. Mike
During the day I'll set the bow anchor with a casual 3 to 1 scope if it's calm but overnight I run it out to 5 or 6 to 1. That's always measured by figuring depth to submerged rode/chain, not from the bow roller. IE: 10' of depth equals 50-60' of rode and chain at the waters surface. When in doubt.... Chapmans.
Be aware of prevailing wind expected overnight along with tide and wind/weather changes. The east coast almost always gets a strong easterly overnight (unless it blows nw from a cold front so try to pick your anchorage with peaceful windward protection in mind. On the other hand wind on the nose with a close leeward(at your stern) shoreline is asking for trouble.
If the wind pipes up be very aware of chaffing of the anchorline as this boat aggressively hunts back and forth, slowly sawing away at your rode. Ideally you'd tie a Y harness to the rode (again, Chapmans) and back to each p/s bow cleat but they're so close together on the 270 that it's almost ineffective in slowing the oscillation except to prevent chaffing.
It's always prudent to have a back up plan (IE; nearby marina/dock/ramp) if things/weather/illness crop up unexpectedly. Always keep a back up handheld vhf radio and spot light charged and readily available. Above all else stay in the boat and anticipate safety related problems. Don't do stupid stuff like eating/serving huge greasy meals that exacerbate seasickness or let anybody get blistering drunk. That just can't end well and endangers everybodys fun.
Stern-to beach anchorage technique was spelled out in an earlier post above.
That outta be enough to get you started. Have fun n be safe. Mike
7:1 in 10' of water is 70' of submerged rode at the water but actually about 80' at the roller for me. 7:1 or 70' showing at the roller equals less rode and a less conservative safety margin. I'd bet we're laying out a similar ratio when all is said n done.
All that said, more is better but with limits when there is some etiquette to be considered in a tight anchorage like many on the east coast can be to allow for a full swing in tide or a wind shift that is similar to others in the anchorage. We've been in popular anchorages when some yahoo rolls in and lays out 12:1 irregardless of how close he is to everyone else who typically lay out between 5 and 7 to 1. It's up to the captain to know his ground tackle limits but if 6 or 7-to-1 won't hold then it's probably time for a new and improved hook.
Mo' betta. Mike
