Ignition switch to button
Has anyone come across a push-button or other replacement for the ignition switches that eliminates the need for keys?
I doubt you'll find a bolt on kit but if you can get the rinker switch wiring diagram I will be happy to draw you a diagram and link you to the parts I'd use to do this. Mostly just a 4 prong relay and a push button switch.
We tinker with stuff like this at the shop often.
I only got one key for each ignition with the boat.
If so then a single safety switch is possible. With use of relays its also possible if they feed off of a different fuse from the battery. One switch can control two relays.
This could be the answer.
And just out of curiosity I wonder if there would be any insurance implications if you disable the key ignition and somebody does steal the boat. Do you take part of the blame for making it easier? I know that if you leave your keys in a vehicle and it gets stolen the insurance company can give you a hard time. Those weasel's will use any reason to get out of a full payment.
Sorry, realize you aren't necessarily looking for opinions, but you know this bunch!
No drilling into the dash and a pretty simple inline install.
If you can get multiple key fobs keep one on the key for the kiddo to use and one on yourself while motor is running. Maybe it works when wet?
I have a hard top so the admiral would have to throw my tall lanky rear end WWE style through the glass to send me over board.
