So how bad is it...
Just got a pair of new props for the Bravo 3, found some "how to instructions" online that said to replace the props, put the throttle "forward" and loosen the first nut, putting it in gear will prevent it from rotating, then to remove the second prop nut, move the throttle aft which will prevent it from rotating the other way, except it didn't. So I won't have a chance to put muffs on it and test it until next week, just wondering if anyone has run into this before.
I got the props off, but I am more concerned that putting in the drive in reverse didn't prevent the props from rotating.
The cone clutch does not like being backdriven and will slip. Normal so no worries.
Read up on the prop timing when you re-install and make sure you use that funky blue grease on the splines when you reinstall.
