Merc trim switch
rasbury
Member Posts: 8,847 ✭✭✭✭✭
My up trim I don't think k ever worked that I recall unless you push into the trailer feature of the switch- so I can assume it is probably not wiring related and is the switch in the handle? Path for trouble shooting?
Make sure you mark the covers before removing them.
If not damaged they can be cleaned and apply some electrical grease before reinstall.
I usually find brittle wires going from trim senders to transom shield.
There are abullet connectors in and around engine/trim pump that can come disconnected.
Thanks @Alswagg
I always adjust the trim by ear, never pay much attention to gauges anyway...but it would be nice to have them work. I bought some new trim sending units off ebay....never could really get them to work proper but it was not a priority either. Only concern I would have is when I get real shallow and have to trim up, don't want to burn up the water pump impeller....will check it out, thanks!
