Vacuflush pump tune up?
                    Just doing reg maintenance on pump. Noticed vacuum pump cycling too often.
Gonna put 4 new duckbill valves in - pretty straightforward.
Never done the bellows & O-rings before. Any tricks to replacing those?
Fairly big job to get to the vac pump. Want to get it 100% & not have to revisit for a while.
(8 bolt Dometic/Sealand SW-12v motor.)
mattie
mattie
Bowl holds water well, doesn't leak down. Imagine it's just the duckbill valves failing. 6-7 yrs old. But I may do the bowl seals too.
Figured I'd do the other stuff at the motor since I'll be folding my bod up in the hull side.
I can leave my boat for 5 days with the pump shut off and on return the pump does not cycle when switched on. See attached as where to look assuming the bowl holds water.
I turn the switch off for the week, come back and turn on, nothing. I always look in the head for the green light because I keep thinking it’s not working.
Ours cycles prob every 15min. Has to be the DB valves or O-rings/bellow. Water in bowl is good, never changes.
I'll tighten clamps on the waste water hoses too when I'm in there. Guess they could be leaking as well.
On the to do list.
