Normal Running Teperature
I just purchased a 2008 Rinker 330 EC. I love it but I have a question. I have twin Mercruiser 350 MAG seacore engines. I read that the normal running temperature should be 170 degrees. Both my engines run at slightly above, 175 to 180. Should I be concerned or is this ok?
My engines run the same temps as yours.
Just for you @Handymans342 my diesels run at 185F on the dot!
This is for raw water cooled motors. Although many report using 160 in salt water for decades without issue.
My diesel runs 175 at idle speeds but 210 at wot which is well within range for my VM Diesel. This is closed loop.
@Handymans342 is correct that the same votec motors used in many of our boats (closed loop) are identical except for the cam and some marine rated electronics as the 5.7 votec found in the same year 1500 gmc pickup. They also run about 220.
Maybe someone with closed loop cooling can chime in and tell us what temp their 5.7 motors are running.
I was always under the impression that the newer votec motors ran more efficiently at 200 to 210 vs the 190 of the 4bbl 4 bolt main days of small blocks.
