Rinker 280 Trailering Dimensions
Hi folks,
I have a 12000 lb Excalibur triaxle trailer on order for my Rinker 280EC. Excalibur says the trailer won't really come set up for the boat since the manufacturer provides limited hull data for them to use. Wondering if anyone here trailers their 280 and if they could provide some dimensions of their trailer and boat position to help me set up my trailer before heading to the launch. Would hopefully save me some messing around and multiple attempts. Even better would be someone with an Excalibur triaxle but I think that's wishful thinking!
I have done some scaling and measurements off of some google photos but would love something more accurate.
Thanks a lot!
Thanks a lot!
-overall trailer length
-centre of the two axles (between them) to the winch (where boat contacts it)
-height of the winch from the top of the trailer frame
-centre of the two axles (between them) to the back of the trailer.
-bunk spacing (centre to centre)
Also if you have a picture of the boat on the trailer from the other side I could you the third window on that side as a reference point.
Thanks!
length 31 feet
trailer to center of roller on winch stand, 45”
Tongue to center of first axle, 22’
tongue to center of rear axle, 24’9”
center of trailer to first bunk, 9 1/2”
center of trailer to outer bunk, 24 1/2”
If so you can get it situated exactly how you want both for hull support and towing.
Is this your new place cable guy? Looks like you upgraded to some more leisurely country life 👍
@PickleRick unfortunately my marina doesn't have any of those. I'll be on my own to load it up, take some measurements and see how it sits, unload, adjust, repeat.
I am going to rig up a scale to measure tongue weight.
My Bayliner trailer came with them but I had to add them to my 235fv trailer. I don't know how I survived without them. Retrieval was always a nightmare unless someone was in the water to guide the rear hull in place while I drove up the ramp. Any cross wind or wave made it a battle.
