please help
tnaking2006
Member Posts: 15 ✭
new to this, my problem is I lost my navigation lights,horn,blower and bilge, but my radio still works and she will start, what am I overlooking? i have continuity to stern and bow nav lights tho, checked my fuses,they are good, didn't check blower or bilge for continuity, got to frustrated..lol thanks alot
That switch might be the dash light dimmer. Took me a month to figure that one out due to my faded switch symbols.
Pretty much what was said already. I'd head to the battery selector switch too. Contact cleaner/sandpaper/wire brush and di-elec grease are maiden voyage staples. Also check your battery cables for a corroded connector or eyelet or added wiring from a prior owner. An intermittently bad ground can also frustrate your trouble shooting. Basically look for corrosion and failing wire.
Good luck and be safe. Mike
