2002 Rinker 310 No 110v to heater, started diagnosis but now stumped
 Rinker310_LI
                    Member Posts: 22 ✭
Rinker310_LI
                    Member Posts: 22 ✭
                    On my 2002 Rinker 310 which is new to me, I am diagnosing the hot water heater and have done some basic tests but hit a wall just now.  I checked for 110v voltage at the heater and found nothing , confirmed breaker is on and shore power is working for all other circuits.  I then pulled the panel and the idea was to check for 110v coming out of the hot water heater breaker but was stumped when I realized that this is a much different set up than residential.  I checked the wiring diagram and confirmed that the hot water heater wire from the panel should be red and that is the same color as the wire coming out of the panel switch.  Just for kicks, I tested the breaker switch for continuity and it passed.  All of the electric out of the panel past the switches flows through these square connectors.   My question is how to try and figure out which feeds the water heater!  I have some photos which aren't the best but if anyone is kind enough to share knowledge they may help.
                2002 Rinker 310
Next step is to turn off all power and unplug each one at a time and at the heater block, jumper the white and black wires until you find which one behind the panel feeds the heater.
@Ian
@raybo3
Check out my connector at the water heater. Corrosion like you both said and this looks like it may have overheated. I actually found and confirmed power to the feed wire at the panel and that's all good, its live until it disappears somewhere behind the head and before the water heater. Then i checked this wire before the corrosion and connector for live voltage - no power. Also no continuity so I have a break somewhere whether its an inline fuse or a physical break. I think I might be able to get to the wire through the access panel in head under the sink and see if there is something obvious. Otherwise it's fishing a new wire from the panel. The panel in my 310 is forward of the head and water heater is in the aft cabin which is after the head - not terrible but also not great.
Thanks for the advice.
I believe I am considering this a winter project for now.
Note - same connectors are used for the feeds from the shore power sockets to the distribution and may go the same way. As mentioned I have replaced the main with a locking 30A plug and socket.
@Rinker310_LI - stay safe down there the next or so.
Raining up here (Albany area), secured the boat, pulled the dinghy today and watching levels on club cameras.
