Remove the cover plates on the arch sides and remove the 2 each nuts, lock washers and regular washers on each side. You can lower it with 2 strong adults, but I HIGHLY recommend 3-4 adults to lower it. Place some folded shipping blankets or pillows at the stern for the arch to rest on. It’s HEAVY!!
There’s a wire harness on the starboard side of the arch. You might have to disconnect it, there should be a connector under the cover plate. I had enough slack and didn’t have to disconnect it.
About $10k for a hardtop for a 330/340/360 or 370ex (all the same part).
