Macerator Wiring and Other Electrical
Squatch68
Member Posts: 62 ✭✭
The PO of my 08 280 had installed a jabsco electric conversion kit for the head. He tied it into the vacuflush switch and breaker. The breaker trips constantly since its only a 10 amp breaker and the unit draws 24 amps. Was planning on running a 10 awg wire, changing the switch for higher amp, and changing the breaker to 25 amps but then noticed the macerator breaker in the battery panel is 20 amps and 10 awg wire. My boat does not have a macerator (aside from the electric conversion of course).
I am wondering where the macerator wires from the breaker terminate? Also wondering how to gain access to the wires that are run to the head currently (through the mid bilge maybe?) Also does anyone know the path rinker took to run wires to the switch panel above the tv?
