IAC Do we have one. Idile Air Control
We had a friend that has a 2003 Rinker 32" and he told me that he had a fire on his boat and it was from a bad IAC it looked like a green foam filter. I looked it up and I did not see that for a 2006 342 Rinker. Dose anyone know.
My Rinker has the 350mag mpi and has that loud hissing sound at idle. Your telling me it's just missing a foam filter? That would be sweet!
do you have a vacuum leak?
this is 'a' IAC, not necessarily the one you use.. the brass tipped plunger is operated by a tiny motor that is controlled by your computer to move in or out, and adjust to control the idle speed...
these things get gummed up w/ carbon easily, and need to be cleaned.. if you go the cleaning route, I highly recommend you take great care not to move the plunger- as the computer loses the mapping of it's position easily, and the only way for it to relocate that is to dump 'learned' environmental tables from the PCM, and readjust... even then, it's a crap shoot..
what you will discover with an older IAC is that the computer has adjusted the thing out to allow more air, because the gumming has created a restriction- that restriction is accompanied by the hissing sound you're hearing.. or, could be, anyway...
clean it.. I recommend you go ahead and pull the throttle body all together and clean it well with throttle body cleaner, avoiding direct contact with any electrical components on it.. but it doesn't end there... the next thing you gotta do that gets glossed over: pull your positive cables off your battery(s)... the PCM needs to dump any learned data and relearn based on new parameters... there are two distinct tables, one long term and one short term (similar to fuel trim expressed in Long Term Fuel Trim or LTFT and Short Term Fuel Trim or STFT)- the short term data collects several times a second, and the long term tables is a result of short term averages.... in order to make sure your computer is operating properly, you gotta make sure the devices it uses to monitor are operating within parameters expected.. so.. clean (or replace).. reset.. let 'er learn... same holds true with every principle sensor on that engine.. when the device the data originates from changes, the environmental data no longer holds true and has to be dumped..
"It idles fine. When we run at 1/2 throttle it bogs down and when we run it that way and give it full throttle it bogs down and can not get up on plane. So is it the IAC our could it be a fuel filter clog"
I'd check the fuel supply too but if I recall there's an engine computer controlled rpm limiter for certain issues aside from fuel problems? It may be a completely different issue that a code reader would easily find(as BD and others said earlier).
I'm with DI on this one. $95 worth of kidney solvent has some excellent potential too..
Just sayin'. Mike
Consider it done! lol
