Can't fill my potty!!
I have 2005 fiesta VEE 270. Can't remember the toilet manufacture but it is a manual pump. Turn switch to left pump in some lake water, and do your business. Then flip switch to right and pump waste into holding tank. I can hear the water is close but bowel will not fill. Suggestions? Boat has only been in water a few weeks, and it worked a few times. Can't imagine it is clog up. What side so boat is pick up tube for lake water?
I would guess the through hull valve is either closed or something got sucked in.
The through hull valve should be under your aft cabin mattress.
