Help!!!! Oil leak
Hello guys and gals. Have a new to me 1995 300 with twin 5.7 mercruisers. Have only had the boat a couple weeks and been out maybe a total of 4 hrs. I checked the oil before our first quick outing and levels were good. Took the boat for a longer 1.5hr cruise and when we got back to our slip I wanted to check the bilge to see if we took on any water. To my dismay I found oil and lots of it. Checked both dip sticks and almost none showing on either. I’ve started feeling around the engine and found there to be quite a lot of oil on the right side below the exhaust manifold. These engines have the remote oil filters and I’m wondering if maybe I’ve got leaks. Both engines are oily on the right side below the exhaust manifolds. Are these remote filters possibly the problem? Help! Thanks in advance
Jake.
Jake.
Yes, remote oil filter and lines can be the issue. There are 2 seals where the remote adapter is. My starboard engine was leaking there before I replaced the seals. I also had an oil line crack on me!!
You'll want it for multitude of boat maintenance, examination and repairs.
Prefect for helping to find leaks between 2 engines you don't fit between.
