lube tank
is it possible to clean out the drive's lube tank? how would you do it? I may have found my annoying, intermittent PIA, I have had a quick beep and motor shuts down, turn key and it's running fine. this has happened about 4 time in 3 years, don't know why. none of the gauges changed from normal, oil pressure at 50ish psi, temp around 170' and volts at 14. someone said they had the same thing on their boat and it turned out to be the drive lube tank float. yesterday while we were out it happened twice but it didn't kill the motor only stalled, one beep and stalled bfore it stopped it was back to running smooth. any suggestions? I'm soo stumped!!
