Thoughts on repowering....383?
SeaHare
Member Posts: 194 ✭✭✭
I currently have about 1100 hrs on the ol' 350's.. They still run great and are virtually trouble free. However, im starting to prepare myself for the time they decide to give up the ghost. Whether its this year, next year, a few years....who knows.
Anyway, when the time comes im thinking about building these 350's into 383's. I have read till my eyes bled on what it would take so im pretty familiar with engine talk.. So for one, would it be worth it to spend the extra money and build 383's or am I opening a can of worms i dont want?
Current engines - 2001 5.7's
880 roller block
906 vortec heads
880 roller block
906 vortec heads
01 FV 310, 5.7s carbed, B3s
Put all your accessories and bolt on parts from your motors onto the new blocks. They can use your serial number to tell you exactly what motor would be a direct fitment.
Add fresh water cooled if not already equipped.
Then sell your good running blocks for a pretty penny while they are good runners. Stick some boat bucks back into your bank account.
You'll likely need to use that cash to pay for new props to account for added power.
I wouldn't say its opening a can of worms if you are keeping the boat for the foreseeable future. Its not worth the extra cash if you're just going to flip the boat.
Isn't every 10 hp added 1 mph faster roughly on a gas motor?
I'm not sure if the ecu needs a reflash for the 383 upgrade, @J3ff can chime in. He has one in a 270.
We just repowered a 6.0 in a Chevy truck with a newer motor/50 some odd rated more hp 6.0 gm crate motor and didn't require a new tune but thay may be different with your application.
Currently have 2bbl intake and carb so i assume i would also need to go to 4bbl carb and intake for 383
This is on an FV310
I could care less about speed...my current 30mph cruise is fine.... im just looking for that extra oomph when i have a boat load of people and full gas to get up on plane
A 383 long block from Michigan Motors is about $6k... i was hoping to be around $3-4k to build my own...
Even if it didn't give much more power on top I'd think running on the small venturi at lower rpms would lower fuel consumption vs the 2bbl
Since he's rebuilding what cam would you recommend?
I've heard some stock gm vortec truck cams are even and improvement over the marine cams.
Its been a while since I looked at the specs but the stock vortec 5.7 cam didn't look far off from the marine 5.7 cam. The price was far off between the two.
I stand corrected. After searching the part number I found that the 14097395 cam is a stock GM ramjet 350 crate motor cam and 383 cam found in stock gm crate motors.
It is also a stock replacement for mercruiser without the marine mark up price tag.
Crane actually makes some slightly more aggressive cams for maine applications. This one stuck out to me because of both price (affordable) and great torque numbers from 2500 rpms up.
Also no valve trian mods needed to run this cam on stock vortec heads/roller block. Budget build for those of us who don't want to have to drink natural light all summer long.
Talk to your engine builder first before buying parts. Make sure what you buy they are comfortable and familiar with using.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.baylinerownersclub.org/forum/current-topics-gc6/technical-discussion-gc12/47265-383-quench-piston-compression-gctid411407&ved=2ahUKEwi26Y_l29zyAhXVQzABHQkSAdoQrAIoAXoECBAQAg&usg=AOvVaw2YVZB0g94SHtY7_TeRlj3s
This thread goes in about compression, piston style and how some builders may vary on opinion.
I certainly would use a marine cam, im aware of inversion with auto cams.i just havent really looked at any yet and dont really know what to get
So would the flywheel from the 350 be able to be reused? What about initial timing the 383.. i know my 350's are 8 or 10*BTDC... Would it be the same for the 383?
I was thinking for a carb using edelbrock marine 600 or 750 cfm and edelbrock performer intake 4bbl
Pretty sure my 2bbl mercarb wouldnt cut it
I don't see why you'd want replace your flexplate, the shop will ask for it when they check the balance of the crank. So long as it's not damaged.
I don't remember timing off the top of my head, nearly everything I run now is diesel.
8 degrees initial timing is what I remember but my 5.7 was old thunderbolt bolt ignition and thats been 3 years ago .
