Simpson Lawrence Horizon 600 Gypsy issue
CaptainDP
Member Posts: 14 ✭✭
I have a Simpson Lawrence Horizon 600 windlass on my 2000 Rinker 340. I had trouble with my old rode at the chain connection. It was getting torn up and I attributed that to the age of the rode. I replaced it with a new Lewmar 3 strand with 1/4" G4 chain. We were anchored yesterday and it started slipping on retrieving the anchor and I had difficulty getting it to transition from rode to chain at the knot. I see some wear on the teeth of the gypsy and suspect that is my primary problem.
1. Is there agreement that worn gypsy teeth would be the problem, and
2. How difficult it is to replace the gypsy? I see it online for about $250 or so but I'm pretty much a mechanical dunce.
Thanks!
Thanks!
Best Answer
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
I'd check the chsin, if I remember I think Al mentioned something about the bbb chain?Past owner of a 2003 342FV
I had to loosen the gypsy to get the new rode loaded and I've tightened it up (perhaps not enough).
Any thoughts on a solution?
