How to order new steering cable?
Stever00
Member Posts: 145 ✭
My boat is looking like I need a new steering cable. Will I have to pull cable in order to measure and order new one? Anyone at Rinker who can give cable number for a certain model boat. Why is everything you need for a boat so difficult to find and replace?
Best Answer
YYZRC
Member Posts: 5,365 ✭✭✭✭✭
The part number was right at the engine.
I have another problem . With the steering cable unhooked cevis pin out I cannot move my outdrive by hand . It is stuck to the left. You can take bottom Clovis pin out to lower unit and you can move the outdrive back and forth. I even loosened the hydraulic lines on actuator and still could not move outdrive back and forth. It's like actuator has my outdrive locked in one position. I'm wondering if actuator was my problem to start with.
