Winterize engines, boat in water?
Cant find any info on winterizing engines in the water. i dont see any shutoff valves for the water intake hose coming from the transom to the sea water pump.. Wont water rush in if i start pulling blue plugs? Or can i just drain it normally from the seawater pump, t-stat, and main drain under the power steering pump. Then fill with pink stuff. Any help appreicated.
