Trim/prop seal leak? Sheen on water.
Hi Everyone. I was out at idle yesterday and noticed some sheen on the water. I noticed while engine is running, little droplets of what I believe is oil, were coming up to the surface from what I believe is my drive. At first I thought fuel but I dont smell anything. When I was in my slip I raised my outdrive all the way out a ton more came out. I checked my trim reservoir and gear reservoir and both dont look to be loosing too much. I have not ran the boat much nor on plane. My question is, trim seal/line or prop seal maybe? Also my main concern, is the boat safe to use in terms of damaging my drive? I have a lot of plans on the boat for this holiday weekend so I want to be sure I can go out, even if I dont trim much or at all. Thank you for al your help!
Patrick
06 Rinker 270
06 Rinker 270
Water in the trim rams/leaking trim lines = no big deal (other than environmental impact)
Try moving the drive up and down with the engine not running and see how much of a sheen you get. Probably a leaking trim line or fitting (common failure), especially if they're original.
If I trim up and down without engine water and I do or do not get oil, what does that mean?
06 Rinker 270
The other possibility is that you have a leaky power steering cooler. How's your power steering fluid level?
06 Rinker 270
06 Rinker 270
06 Rinker 270
https://rinkerboats.vanillacommunities.com/discussion/12005/sigh-oil-leak-big-one/p2
06 Rinker 270
I am grateful for everyones help.
06 Rinker 270
06 Rinker 270
