Trim/prop seal leak? Sheen on water.
Hi Everyone.  I was out at idle yesterday and noticed some sheen on the water.  I noticed while engine is running, little droplets of what I believe is oil, were coming up to the surface from what I believe is my drive.  At first I thought fuel but I dont smell anything.  When I was in my slip I raised my outdrive all the way out a ton more came out.  I checked my trim reservoir and gear reservoir and both dont look to be loosing too much.  I have not ran the boat much nor on plane.  My question is, trim seal/line or prop seal maybe?  Also my main concern, is the boat safe to use in terms of damaging my drive?  I have a lot of plans on the boat for this holiday weekend so I want to be sure I can go out, even if I dont trim much or at all. Thank you for al your help!
Patrick
06 Rinker 270
