Vacuflush leak…HELP
I made a few repairs to the vacuflush tonight. One of them being the ball seal. I cannot get the toilet bowl to seal at all! I have a brand new set of seals. I have checked five times to make sure I had the right seals that the website recommends. I have the thin seal with “this side up“ facing up. The thicker seal above that. The holes in both seals lined up with the pinpoint. Installed the half moon brackets so the front sides were touching and then tighten the clamp down. I must’ve done this 10 times and still have the same leak. What am I doing wrong?? Air show this weekend so it is extremely important I get this up and running! TIA!
I was thinking that too…if I have to, I’ll set it in a thick bead of silicone and clamp it down for this weekend. 🤷🏽♂️
How tight can you go with that clamp? I’m afraid if I go too tight I’ll snap the split ring flange.
I was just worried that I was going to break something…but now it’s all good! Thanks for the replies!
