Remove Lowrance 520c from dash
Is there hidden screws or a panel that pops off i cant figure out how to remove the original  lowrance chart plotter. Spent over and hour searching online and not a word about it or even an installation drawing in the original manual.
    There is screws on the back of it that hold it on. I removed my switch panel to access it.
  • skyman2112skyman2112 Member Posts: 26 ✭
    I was wondering if that was it. Thanks again man!!! Did you ever replace the transducer? Mine comes with a fwd/side/ bottom scan. No way to make it work on the inside of the hull i think.
    I am adding it to my transom. I have seen people add them on the inside but it doesn't seem like a good idea and I also want water temp.
    I got the split shot transducer, its flat on the bottom all you gotta do is epoxy it to a clean spot on the hull. Nothing too it
