Suggestion on Long Island Mobile Marine Mechanic?
Rinker310_LI
Member Posts: 22 ✭
anyone have a recommendation for a mobile marine mechanic service on Long Island? My Rinker 310 is in Freeport , LI (Nassau County). I need a sea water impeller changed and looking at the access on the starboard engine its something I do not want to tackle on my own while in the water.
2002 Rinker 310
Best Answers
Member Posts: 3,018 ✭✭✭✭
@Rinker310_LI I agree it’s a PITA to get to and I did mine when in winter storage. Moving blanket on top of engine and laying on top feet to stern, wrestling the hoses off the rear of the pump is awkward at best and I’d not want to have to deal with trying to plug them. If it were me I’d put the money into hauling/lifting out and do both at the same time. -
Pat310
Member Posts: 601 ✭✭✭
Dream_Inn Member, Moderator Posts: 7,861 mod
So, I used to own the same boat, 2002 310 and did change my own impellers every other year (I believe a total of 4 times). It is definitely a bit tight. I'd say do it over the winter (like a few weeks before putting boat back in water). This would give you some time and not have to hurry. It also allows the old impeller to sit in the pump, not the new one. As for the hoses, spray some lube on the hoses when reinstalling. It will go back on much easier. Also, when removing hoses, take pump off engine first and have on floor. It allows you better access and can twist it a bit more. Opposite when reinstalling hoses (at least I think so). Install pump on motor first, then you have something to push hoses back onto. I can't say I ever had to lay on the motors to do this job though.I'd say that $^%@ generator impeller is the worst thing on that boat to change. It is all by feel, can't see. Yes, you can use a mirror, but it was a pain.Now, the worst engine impeller I ever changed was the stbd side on a 2000 340. For changing out both impellers, I actually got a used Nissan 2hp outboard! :-:smile: (it was kind of a deal from a friend that had an extra and I needed one). (an older 270 came in a close second because of that little catch that should've been grinded off)Dream 'Inn III -- 2008 400 Express
