Kohler 5E Disassembly
On my model boat - 2014 310 EC - it is my understanding that to remove the generator (Kohler 5E) you need to remove the pulleys and assorted other items from the front of the starboard engine, then you can hoist the genset out in one piece.
My question: Can you disassemble the genset into smaller pieces - thereby not even touching the engine - as long as I am planning on not reusing the genset?
It does not work currently. It is a pain to access and work on - and quite frankly I'd rather have that real estate in the engine room for better access to the engines, bilge pump, etc. -- and/or add extra batteries.
So would I be able to remove it by taking it apart piece by piece? And any logical steps to disassembly?
note I had a tech do all the work I mentioned, I did not disassemble myself. Not sure what that took.
It's just one more thing we'd have to maintain ($$). I've learned from all of you that's why gensets go bad -- from not using them regularly.
And with evolving technologies, I might be better off parting it out now - and if the time does come to get something down the road a replacement would be smaller and/or more efficient.
