5e generator now purrs
toolmaker312
Member Posts: 128 ✭✭
The initial problem was surging. I first changed plugs. No change. Next fuel filter, no change. tried adjusting carb, no change. I then took off the float bowl and found major contamination. My first thought was to rebuild, but the fresh water tank needs to be moved to get the guards off. I didn't want to chance doing it twice so replaced with new one. Now runs as it should. Note: To get the rear spark plug out I had to removed the coolant hose to access the plug, because rear sound cover was either stuck or non removable. I used a small hose attached to the spark plug tip to get it started in the blind hole.
