Multiple failures of Merc power steering hose
LaReaLaRea Member, Moderator Posts: 7,856 mod
Starting a new thread:  Why would my power steering hose fail three times in three years?
It's the high-pressure hose from the pump to the steering ram.  All three times, it failed at the quick-release connector on the ram:
3/2019:  slow leak
7/2020:  hose blew out of fitting at cruise speed
9/2021:  hose blew out of fitting at cruise speed
It's not an issue with the pump or ram.  A few months ago, while troubleshooting a separate issue, I replaced the ram and swapped the port/stbd pumps.
I'm using OEM parts:  Quicksilver 32-8M0063021.  This part is rated for 2250 psi.  I think most steering pumps run around 1200 psi.
Aside from the obvious inconvenience and cost ($150 each), this is a dangerous fail.  When the steering goes away at 3900 RPM, the boat turns hard to starboard.  Imagine that happening in a narrow channel.
So I'm looking for suggestions and guesses.
--Anxious in Alexandria
