best teak-like flooring?
Hey everyone..I have been comparing Nuteak,plas-teak ect..
any real life testimonials for salt water use boats??
any better made brands to go for?
I already know I have to make my own templates ,as nobody has the floor plan on the rinker 1999-2002 fiesta vee 270 model..
If you can validate these sizes/shapes, and then give me a measurement for the swim platform- I can make you pe-eva mats- 6mm if not 10mm thickness, and i think i have natural (a little bit lighter than khaki) and black in stock.. i have light gray over black in stock.. I can get whatever colors you want- and- i can cut custom logo's or simple line graphics in it for you...
my cost for a job like this is $1700, including the custom graphics.. plus shipping. it would take me a week or so.
the material i use isn't el-cheapo.. it's by far the better material available- which means the layered EVA is consistent in thickness- 6mm would be 3mm black base and 3mm whatever other color.. 10mm is 5/5... lessor quality material differs in depths and often times within inches (instead of a gradual increase/decrease, which still isn't acceptable)...
I have special bits and cutters that cost me a small fortune, and use both a vacuum table pulling 26g or so, as well as pneumatic rollers to hold the material firmly flat while the cnc works it's magic. I use a specially designed knife to cut the edges smoothly with a tight radius where needed... the backing is a 3M adhesive that is pretty dang good at what it does.
respond here or PM me- as well as anyone else who may be interested.
by the way- seadek has your measurements, but they'll still require a template... ever asked yourself 'why'?
I would not do sea deck outside on a swim platform. Two boats on my dock have sea deck which was professionally done and is only 2-3 seasons old and both swim platforms are bubbling up. But inside the cockpit that would be ok. Not perfect though as you have to stick it down.
best I’ve ever had was luxury woven vinyl carpet. I think that is the best option in the cockpit and probably for the swim platform too.
EVA WILL fade in UV regardless of what advertisers say- but- it'll last upwards of seven or eight years with fair ease all the same. I carve these things up, but i won't install them as it takes way too much time to get that surface prepared correctly.
For about $300 I had enough flooring to do the cockpit. I cut it myself with some Fiskars PowerArc scissors and then had a local shop add Sunbrella binding. For $500 or so I have great carpet. Here's a photo before final trimming and binding:
I had EVA foam on a previous boat and it's a pain. It is easy to mark up and doesn't look great after a year of boating. I also don't like the hodgepodge of pieces that you get when you do EVA foam (due to the size of the sheets); all the cut-outs plus the engine hatch cut-out make it look like a jigsaw puzzle to me. Fine for a bass boat but not very classy IMO. I love the look of my one continuous piece of carpet!
What is best???
need the teak look.Whats best for durability,regardless of price??
Thanks for the pattern 212..I appreciate that.
Liberty...based on what you said....I am pretty confused at this point.I .was leaning to seadeck on the inside..and perhaps flexiteak for the swim platform...for durability..with the sun.
good choice?
mixing and matching is not the aim though..
any other guys that have done this?
marine mat is great on our pontoon..but the Rinker needs the teak look..I am thinking..
I do think eva is out of the question, not tough enough ,right?
thanks everyone!
max
I believe its made in the USA but not 100% sure on that. The newer Plasdek products dont get as hot as the old versions. Mine was installed in July of this year and we have not had any issues with heat at all. it gets worm but not hot.
We had Seadek on our last platform and it was good with the exception of the dogs snagging it up a good bit and it gives up adheasion after about 7 years in.
We have Marinemat in the cockpit and Plasdek on the platform. They are very similar and work well together
The new "cool" technology that they can put in to PVC will definitely make it cooler in the sun than the 2007 product on my boat, but the difference is only 10 degrees. I just cant imagine 10 degrees makes that big of a difference but maybe it does. Whether my attic is 100 F or 110 F its still really darn hot!!! LOL
We have dogs...Seadek definitely would take the beating...
Admiral is always after me to cut dogs nails..
They don't like it much though..
just curious..I thought about adding the double captains chair..
Dogs and seadek.??..hmmm..could be ..not so good.
