Remove Radar from Radar Arch for Transport
I have a 2004 342 Fiesta Vee need to remove Radar from arch to transport
Best Answers
Cableguy Greg Member Posts: 5,047 ✭✭✭✭✭
There should be access panels on the underside of the arch to get to the bolts and electrical connections.
Go Steelers!!! -
Handymans342 Member Posts: 10,375 ✭✭✭✭✭
4 bolts, hard to get to but doable. All the wires need unhooked under the dome top
There is a philips screw holding a small plate on, on the back of the pedestal. Remove that and yes there is a plug there that you pull. That’s it for disconnecting power and data. Also pull the 4 large nuts holding the pedestal on to your boat. The threaded rods coming out of the pedestal are studs so you can back them out of the pedestal so that they don’t damage anything in transport.
for transport we left the antenna on the pedestal, wrapped everything well in blankets and sleeping bags and tied it in place down below on the boat. Worked well but we should have removed the antenna just to be safe. I later did have to remove the antenna to send back to ray for warranty work.
easy to remove antenna, 4 nuts and it pops off. You must pull it straight up to it damage the coax post on top of the pedestal. Cover that post well, we used a plastic cup and a lot of electrical tape to protect. Putting the antenna back on was easy, admiral and I very carefully aligned and slid straight down. There is just a small amount of play.
