Camper Canvas redesign or modifications
davidbrooks
Member Posts: 1,418 ✭✭✭✭
I wanted to start a new thread regarding the canvas and sides to see if anyone has tried to improve upon the standard OEM design. Post your pics of the mods you have had done. Why you did it and what you like about it. I have been calling around here in Annapolis to get some estimates to make some changes. I have some panels that need to be repaired anyway so i just thought it would be a good time to see if it made sense. My first priority is everything aft of the radar arch. Here are the items i was thinking of:
- Top canvas piece seems too small. Almost as if it needs to hang about 2 inches lower on the sides for some overlap.
- The corners of the separate pieces don't close up.
- Has to be a better way to fasten it to the sides of the boat.
- It is stretched so tight there is no wonder why stitches or seams don't last.
- Are snaps the best option?
- Is there anything i can do to help with the station wagon effect? it is both the carbon monoxide as well as the sea spray?
- Do i get rid of the big roll up rear portion that has a screen over it? Replace it with smaller ones?
- Eisenglass or Strataglass for the clear portions? Is it possible to get the ripples out?
I never remove any sections of canvas. If I need fresh air, it takes two minutes to roll up the canvas. When I'm leaving after the weekend, it takes two minutes to close it up. It's so much easier than using a cockpit cover.
The front section center panel is removable or roll up slightly wider than the windshield door, it makes it easier passing through or passing up or down the sun pad. The center piece has vertical velcro strips that attach to the outside of the side panels.
I also changed the way the 2 top panels attach to the arch by having approximately 2" strips that attach to the arch through tubing and then zippers to attach the tops.
I did not go with Eisenglass because when I am driving I am looking through the windshield most of the time. I had it on my last boat but found it harder to handle in cold weather.
