Good news, bad news
Brought the boat to the yard for winter storage on Monday. Mentioned to the yard owner I had a little water coming in all season long. Just enough to kick in the bilge pump about once or twice a day and could he check it out.
Based on recent threads about rotten transoms I was getting nervous what he might find.
Went today and he told me it's coming from the fresh water tank.
So good news my hull/transom seems to be intact. Bad news, probably will need to pull the port engine to get a new tank in.
It would slowly drain the fresh water tank into the bilge over about 2 weeks. Took a long time to find the leak.
Finally found it when the pink was poured in the fresh water tank for winterizing.
Hopefully just a fitting.
The outlet elbow on my tank looks wimpy and fragile. I can't believe it has survived 14 seasons plus a winter sitting on the ground under the boat during the reno.
Moving 50 lbs from the transom to the bow is like taking 80 to 100 lbs from the transom.
Especially important for us under powered boats.
