Shower drain routing?
Hi all, I have a 96 FV 266, and noticed when winterizing the shower drain would not drain. I have the pump mounted just inside this access that is more like a water pump, rather than the true shower box. I can barely get my fingers on the drain from the access port on the steps, and it looks like this drain runs forward a few feet, then back to the pump. I have no idea how I would get to the drain itself if it does not pop or unscrew, but cannot imagine that being the setup due to potential leakage. I am hoping to snake a piece of 1/8" cable in tomorrow to bust the clog, but am trying to plan ahead too. The pump turns on and seems to pump OK. I may also try to DC the drain line at the pump to confirm it is a clog. Any advice or helpful hints? Thanks!
So, here is the pump mounted on the wall, going from the shower drain to the side of the boat just under the sink. I disconnected the intake hose via the ears on the hose (LIFESAVER!), and was relieved to hear bubbles almost instantly. Not sure if I had a light clog, or the pump is weak, but regardless, changing it wont be the worst job ever via the cabinet access.
Here is the bigger problem if something starts to leak. This was taken in the blind with my phone, through the circular hatch in the steps. (Can
Normally, the shower drains into a sump pit that has a float-activated pump. It looks like this:
